120 LD90c force in a 1991 bayliner
rmtofish
i had a blown head gasket i fix that and my compression checks out ok but now im getting water in the bottom two cylinders if any body has any info on what might cause this please help
jerryjerry05
Re: 120 LD90c force in a 1991 bayliner
Gasket not installed right or the head is warped.Or the bolts not tighened in the right sequence.What did you tourqe the head bolts too? 20 ft#
Take it off and check the gasket.
Put the head on a piece of glass and see if there are any high or low spots.Take the glass and check the block for clearance.
