120 L-drive Mystery Hose
JDusza
Hi,
I'm replacing the U-joint bellows, exhaust bellows and a corrugated hose on the lower end of an L-drive.
I can't figure out from the parts list which hose this is or its part number.. Can someone help me?
I can tell you the hose is chafing the exhaust bellows through. It's a corrugated, wrapped hose maybe a little over an inch in diameter.
Thanks,
J
pnwboat
If it's number 11 or number 12, regular heater hose of the correct diameter from any auto parts store will work. #11 is the cooling water exit from the block into the exhaust. #12 feeds the water into the block from the water pump.
