oceaninabox
Thread starter- Joined
- Sep 26, 2009
- 32
So my mechanic told me I have 2 cracks in my exhaust manifold. I can see both cracks. One is on the outside that I am going to drill and use JB weld to fix. Here is my question to you guys. Inside the port"circled in red is a curved shape seperator. It has a crack on the manufacturer seam. Since both sides of where the seperator is goes back into the same area, which I believe is just hot exhaust. Will this have to be welded as well? I could see if it was water on one side and air on the other. But here they both go back and is an open channel. Hope this makes since. Basically I can stick my finger on each side of the seperator and touch my fingers so I know they are not seperate...
