120 Force Trim limit switch and Quicksilver trim rocker
FishJC
I have a 1996 120 Force OE184464 and the unit<br />does not have a high limit switch for the trim.<br />Is there a mercury switch available for this?<br />Also need to find a "rocker switch" that came<br />off my QuickSilver 3000 side mount for the trim.<br />The switch is ok, just need the small plastic<br />rocker piece. Any part numbers or suggestions.
roscoe
Re: 120 Force Trim limit switch and Quicksilver trim rocker
Do you have a Commander 3000 or a Commander 3000 Classic?<br /><br />To identify:<br /><br />THe 3000 Classic has a round throttle only button.<br />trim switch assembly 87-18286A31 OB $48.00<br /><br />THe 3000 has kindof a "U" shaped throttle only button.<br />Trim switch cap, 824027 $2.30<br /><br />I hope you have the 3000, and not the 3000 Classic.
FishJC
Thanks roscoe - Got the cheap one. I appreciate the help and see you on the water here up in the northwoods of WI. Walley fishing in Depere was ok this weekend.
