memphisbobby
Thread starter- Joined
- Apr 23, 2005
- 4
Hello all. I have a 1995 120 hp force in what i think is pretty good shape. Has good compression on all cylinders and has been running very good of late. That is until.<br /> Replaced stator about a week ago.<br />Ran boat 1 time and it ran good until I saw the volt meter on dash showing 17 volts.<br />When i got to the boat ramp and tried to restart motor it would not start.<br />Took it back to mechanic and was told bad starter,which I do believe.<br /> Replaced starter.<br />All seems to be well now but still showing 16.5 to 17 volts at wot.<br />Shows correct voltage at low rpms.<br />Other than the battery what will I hurt and also what maybe the problem if anyone has a guess.<br />Thank you very much.<br /><br /><br />bobby
