120 Force No Spark
hotrod39
Yesterday when I docked the boat and tried to start it again, nothing happend. I checked the cut off switch and it is okay. The boat was running fine and now I have no spark. Any ideas? This happenend once before and then the next day it worked fine again. It has been about 2 years since the last incidence. Confused .... Is this a a sign of a bad stator?
lonewolf5347
Re: 120 Force No Spark
I HAD THE SAME PROBLEM ONLY 1@2HAD NO SPARK.HAD TO REPLACE THE STATOR YOU CAN DISCONNECT THE SOLID RED@BLUE FROM THE POWERPACK @TAKE A OHM READING ACROSS THE TWO WIRES SHOULD BE 600 TO 850 OHM READING. DO THE SAME ON THE STRIPE BLUE @RED IF READING IS POOR REPLACE THE THE STATOR.IF YOU WANT YOU CAN E MAIL ME I WILL SEND YOU A TROUBLE SHOOTING GUIDE WITH OUT A METER BY SWAPING WIRES lonewolf5347@cs.com good luck
hotrod39
That was it. I got the new red stator that was a replacement as found in a service notice
Walter
Hotrod...you lucky dog! Had that failed on me it wouldn't have been at the dock...it would have been in the path of an ocean freighter coming to port in a narrow channel. You outta go buy a lottery ticket or two my friend! Glad to hear you're up and runnin' so quickly.
jasperastro
I am having the same trouble, after hooking up a new battery, i have no spark at all. The engine turns but no spark. Checked all i could with a test light, and i guess ill have to take it to a shop now. Oh well live and learn ....jas....
