120 Force draws current when not running
seastar
My 1997 120 Force draws a few milliamps of <br />curent when shut off. I traced the current <br />to a small (3"x3"x1") epoxy encased block of <br />electronics mounted on the upper right side <br />of the block. Unfortunately, don't know what <br />this block is, nor what it does. Should it <br />be drawing current? If not, does it need to be replaced?
hondon
Re: 120 Force draws current when not running
That would be your rectifier/regulator and you should consider it normal for this charging system to have some parasitic draw when not running.
