Darrendude
Thread starter- Joined
- Nov 16, 2004
- 145
Is it possible to run a 12 volt trolling motor on 24 volts? What componets would you have to change , if any? If you run 24 volts , the amps would be less, right?
I suspect it will work better than you expect for a few seconds, maybe even a few minutes, then the smoke will leak out and it wont go any more. Since you are willing to experiment with going out on your boat and setting it on fire, I would like take this opportunity to thank you for your participation in this forum.<br /><br />Youre right, in general motors are pretty simple technology. Its all in the winding; a balancing act between too much voltage and too little voltage. Either one may let the smoke out, set your boat on fire, and feed you to the sharks.<br /><br />Darrel, unless you are committed to becoming the poster child for Californias public education system, I strongly urge you to limit this experiment to your driveway, if at all. Then you can walk over and throw the thing in your garbage can and have beer with a good laugh.Originally posted by Darren Darnell:<br /> I will do a test and report back. I have a very old JCPennys 12 volt trolling motor. I will try it on 24vt next time I go out. Any predictions?
....Unless you do what I did when I was about ten years old. I literally did just that with a couple 6V lantern batteries. Criss crossed their terminals with aligator clipped jumpers (without any load inline), then another set to the AM radio I was playing with. 12 Volts, worked fine for a few minutes until the latern batteries started losing it because of the direct short in parallel to the load. Those alligator leads did get warm though! I was so disappointed because I could have enjoyed messing around with those batteries for months had I been paying attention.<br /><br />It could get downright exciting if someone were to do this with a couple 12 volt batteries! By the way, I know you didn't mean it that way, Luna. The load leads would be the second set of positive and negative- it just made me remember that incident 35 years ago. It was for me a good lesson well learned.So hook the neg to pos and the pos to neg I guess to get series/24 volt. Can't hurt to try....
