12 into 24 volt
tami
hi i have a motorguied four743 bow mount trolling motor. would i burn the motor up if i ran in with my batteries in a 24 volt series?
Silvertip
Honorary Supreme Mariner
Re: 12 into 24 volt
You are contradicting yourself. The title of your post says "12 into 24 volt". Yet the question is "would I burn the motor up if I ran in with my batteries in 24 volt series?" (which means 24 into a 12 volt motor). So my question is -- Is your motor a 12 volt unit or a 24 volt unit. If it is a 12 volt unit and you feed 24 volts to it just what would you expect it to do? (Hint -- would a 12 volt bulb burn out if you fed 24 volts to it??). On the other hand, if you mean you have a 24 volt motor and are feeding 12 volts to it, the same concept applies using the bulb as an example. Does not a bulb glow with 1/2 brightness when it gets only half its operating voltage? So that's the lesson in voltage. Now you need to clarify which configuration you are really talking about. Electronics used in radios, fish finders, and yes - trolling motor controls is voltage sensitive so you cannot over power it.
