Re: 12 ft aluminum boat
Cool little boat. Sure you can use it on a small-med river. Although, some emergency flotation would be nice. You can use the pink/blue closed-cell insulation foam board from lowes/HD cut it to fit and place it between the ribs, then add a deck on top made from 1/2"-3/4" non-Pressure treated exterior grade plywood, sealed with either epoxy, fiberglass mat & resin, or Spar Urethane, and atached to the hull with stainless steel sheet metal screws. I think it would make a sweet little poling skiff, but y'all probably don't do much of that up there. I say add a deck with some flotation and use a cooler for and aft for seats and hit the water. A 15 hp will move her along nicely.
