12/24 trolling motor question
jakelegboater
Bought used, no manuals. Bass boat has a foot controlled Johnson Seahorse trolling motor. Missing top, so no additional identification available, save a picture if needed.
I don't know if this is a 12/24 motor, but I presume they essentially all are. But, this motor has *no switch* for 12 vs. 24, anywhere.
There is a switch panel on the boat. One switch has top setting "Charge," middle "12," and bottom "12/24 run." One would assume this panel and motor are related, but it is also possible the switch panel was a stock install.
Through experimenting, I have not been able to get the motor to respond differently on any of the three settings. They all seem to do exactly the same thing, regardless of whether I'm wired for 12 or 24 volts. I have run the motor for a few seconds on 24 volt, and seems to work fine. But again, no change in motor behavior occurs between any of the switch settings.
So, the questions are:
1) How safe can I feel running this motor on 24 volts, if I'm not absolutely certain it was built to be a 12/24?
2) Ever heard of a motor having no 12/24 switch, but working on either 12 or 24 automatically?
3) Why is there a "12" and a "12/24 Run" setting on the switch, if they behave the same?
4) What does "Charge" do? What does it mean? If it is related to charging the battery, from where would come the charging source, if there is nothing evident I can plug in anywhere?
Thanks for any and all assistance.
Silvertip
Honorary Supreme Mariner
Re: 12/24 trolling motor question
Many older bass boats were wired just as yours is because the manufacturer had no idea whether a 12 volt motor, 24 volt motor, or a dual 12/24 volt motor would be installed after the fact. The switch panel and switch you mention is required in such a configuration since at the time, few multi-output chargers were available so if the boat was wired with two batteries for 24 volt operation, a single 12 volt charger could not charge both batteries at one. The CHARGE setting allows that to happen through the trolling motor connector. It breaks the "series" battery connection and "connects" them in parallel for charging purposes.
The motor cannot automatically switch between 12 and 24 volts. If the motor was capable of both 12 and 24 volt operation the cable between the boat and foot pedal would have three wires. 12 volt motors and 24 volt motors have only two wires. A 12 volt motor will not run long on 24 volts and it seems to be ok because there is no load on it unless it is in the water.
I can't help much beyond what I've related because I have no idea whether you have two pairs of wires (red and black) going to the switch panel or whether you have three, or if you have just two. Once a boat has been around the lake a time or two, people have a tendency to do strange things with wiring. So until you tell us exactly what the wiring looks like from battery(ies) to the motor we can only guess what you have.
jakelegboater
Your explanation certainly puts it into perspective for me. "Charge" now makes sense, as does the 12/24 run.
And, there are only two wires from boat to motor. The third one has been clipped out. So, it seems my concern and intuition was on track. I just couldn't find any evidence the motor was wired 12/24, and so I guess it's not.
I'm curious, though: If 3 wires are required to operate in 24, why are there just two wires to the batteries ( + and -, wired in serial)? I'm not picturing where that third wire comes in. Is there some form of inverter or converter sitting somewhere underneath of which I'm unaware? I have seen some wiring diagrams online, but I only glanced at them rapidly. Maybe I better go back and look again; might find some clues.
Many thanks.
edited to add: It also occurs to me that this could in fact be a 24-only motor. In fact, it runs very slow on 12 volts. Even with a fully charged battery, sometimes it has a bit of trouble starting its prop, even out of the water, when it's in low. It has only three speed settings: L/N/H. I suppose a 24 volt motor could run on only 12 volts, although slow...yes? I got it with only one battery (12 volts), and have successfully used it three times as a 12-volt motor. So, how would one go about determining whether it's actually a 12-only or 24-only motor?
If it is a 12-only, and I have two batteries in place, would you: (1) run one battery until it's down, and then switch the cables and use the second as a backup, or (2) wire them in parallel and have a larger 12-volt capacity setup?
Silvertip
12/24 volt motors had three wires because they were needed. The three wires were typically red, orange and black. Red and black was used for 24 volt operation and orange and black were used for 12 volt operation. To complicate things even more, some manufacturers flipped the orange and red (opposite function from what I stated above). The fact that the motor originally had three wires, says it is indeed a 12/24 motor. The third wire in a 12/24 system typically went to the positive post on the first of the two batteries. Another scheme had four wires going up front. Two from each battery as I stated in my previous post. The 12/24 switch selected either the red/black, or orange/black pair. The fact that one of the wires was clipped means you still don't know whether the 12 or 24 function was eliminated. What color was that clipped wire???
jakelegboater
Misinterpretation, Silvertip. The "clipping" was not out of the motor, it was on the boat side. The plug itself was wired for three wires, but the orange one is clipped off. The red and black from the plug go on to the motor. There is no evidence that an orange wire exists on the motor.
I got the boat with one troller battery. The only place I can see that three wires was involved is on that plug itself. It was clipped, I presume, because it simply wasn't needed.
This manufacturer is Johnson. Do you believe they would have followed the red/black=24 volt convention? If so, perhaps this is a 24-volt motor. If it is, but is hooked to only one battery, would it run okay, albeit slow?
Your assistance is so very much appreciated.
By the way, I just ordered a new top, as the directional indicator portion of the top had long been lost. In case you know motors well enough to recognize it, here's a link that shows the top: http://www.motortechva.com/PopularOMCParts.html It's the white cover, top row.
Silvertip
Clipping the third wire is really annoying since just because a terminal with a wire attached is not needed does not mean it must be clipped. So now we really don't know what you have. Two wires going to the motor are required whether the motor is 12 volt or 24 volt only model. Only combo motors need three wires. Without a model number or something to go on I can't tell you what you have. A 24 volt motor running on 12 volts will be nearly worthless. A 12 volt motor running on 24 volts may not last long. Sort of like plugging a 120 volt appliance into a 240 volt outlet (which happens a lot when Americans travel in Europe).
If you have only one battery, the only requirment for wiring is that the two wires from the battery match up at the receptacle with the two wires from the motor. You really would not need the switch panel at all for a 12 volt setup. You also don't need it for a standard 24 volt motor since it too requires only two wires. This 12/24 nonsense seemed like a good idea to the manufacturers but as you can tell, it is now, as it was then, a really unnecessary complication. But that's just my opinion!!
