I am new on boat. I got a boat few weeks ago tested in the water works just fine until I replaced strottle shifting cable then thing goes wrong. No power goes to ignition switch and tilt switch is also stop working. Someone out there please help.
Check all of the electrical connections in the areas you were working in to replace the cables. You may have a broken or disconnected wire. Due to the age of the engine, the wiring can be old and brittle. Also check all of the fuses.
My guess is that you didn't disconnect the battery before installing the shifter cable and shorted something. Over on the motor beside the starter should be a inline fuse. It will be on a red wire with a black connector called fuse. (This controlles the power to the switch). If this is not it..
2. Check your battery connection
3. Trace the wires from the control box and look for a broken or damaged wire
