115hp '74 Calco tilt motor
haz77
Hi All,
looks like the tilt motor on my 74 johnson 115 has seized, its a tilt only model, 115ESL743 (or B), found loads of sellers with after market motors but they all use long numeric part numbers & most dont look anyhting like mine, where can I find either my part number or better still the motor?
it looks like this;
Cheers,
Mike.
emdsapmgr
The OEM factory motor you need is not shown in the factory parts diagrams for your tilt only unit. The part number is the factory lists for that motor is: 172543. It's long since been discontinued, but one Bombarier dealer still has a new one left over in stock: Give them a call and purchase it over the phone.
VANS SPORT CENTER INC1855 ALPINE AVE NWGRAND RAPIDSMI495042872 INFO@vanssports.com0172543
haz77
Well this is proving to be a F'in night mare!!
The part number you gave "OMC # 172543," im told is the prestolite part, the Calco is "OMC # 172847".
The OMC 172543 / 382715 = prestolite; ESZ4009, ESZ4012, ESZ4014, ETX4001 & also = API PT112N-NP-3, I dont think these fit my connections.
The Calco 172847 = API PT113N (motor only) = prestolite; EFT4003, ESQ4006, ESQ4007-1, ESQ4009S which can be replace by an API PT114-NPK (a complete assembly), a couple of places seem to have these at $620++.
The API PT114N-RP is a complete assembly, however it = OMC # 172850, 173596 (not the same as above) and = prestolite EFT4003, ESQ4006, ESQ4007-1, ESQ4009S, which are the same as above!!!!!!!!!!!!
Then there is a guy on ebay with this;
OMC 980940
Which looks very similar to a API PT114-NPK / NP-3 but he tells me "The pump number for that Calco that I get is part #172577, for the prestolite I get #172655 and I don't have either. The prestolite crosses into a Sierra Marine #18-6767-1"
The Sierra marine listing #18-6762 =[FONT=helvetica,Arial, Helvetica, sans-serif] 172543 (prestolite) but the [/FONT]#18-6767-1 =[FONT=helvetica,Arial, Helvetica, sans-serif] 172850, 173564, 173596.[/FONT] So seems he has a completlely different numbering cross reference to others!!!!!!!!!!!!!!
Johnson / evinrude / BRP cant tell me the part number for my pump so I cant confirm any of this so how the hell am I supposed to know which part I need or can interchange???
emdsapmgr
For the 1973, 74, 75 and 76 tilt systems, there is only one part number listed for the motor/reservoir, part number 172655. From the factory exploded parts list diagrams at: epc.brp.com Found under the 1974 accessories section-electrical. Since the pump you have may not be in the original factory parts diagrams, I can see the problem it would cause them when trying to look up parts.
haz77
Thanks for the link,
however from that parts list;
730172577PUMP ASSY. USED ON CALCO MFG. PUMPS
01728470172847MOTOR ASSY. USED ON CALCO MFG. PUMPs
Pretty sure the 172655 is the prestolite assembly not the Calco.
emdsapmgr
These Bombardier dealers have one pc of original stock left on part number 172847, pump and motor assembly:
US BOATWORKS INC930 OSAGE AVEKANSAS CITYKS661051850913-342-0011usbw1@cs.com01728471
LEONARD'S OUTBOARD SHOPPO BOX 128 HWY 21KEYSTONE HEIGHTSFL32656 leonardoutboard@bellsouth.net
0172847
