115 stops going fast
dousterhout
I have a 1988 Yamaha 115 with 130 carbs. After they were overhauled the motor ran great. After a couple of hours, it bogged down and stalled when I pushed the throttle down, trying to get on plane. It will idle ok, but I can't do any more than that.<br /><br />I pulled the plugs and they appear "oily". I replaced the plugs and it seemed like it wanted to get up and go, but then died again.<br /><br />The inline gas filter is clean. I had the tank siphoned, and it has fresh gas.<br /><br />Any help would be appreciated. Thanks in advance, Dean
bossee
Re: 115 stops going fast
Fuel pump? Press bulb while You try to accelerate. If it helps You have a fuel delivery problem.
bigbrownbuku
Master Chief Petty Officer
were your pumps rekitted when your carbs were cleaned?
dousterhout
I cleaned the carbs, found junk, she has worked great since cleaned.
