My 1994 engine cranks and runs at low speed just fine. However, when you accelerate the power is woefully lacking and the top speed is probably 60 -70 % of norm. I have replaced plugs, plug wires, and electronic control module.
I replaced the turbojet drive unit two seasons back and have maybe 20 to 30 hours of use on the new unit and I have been careful to not run my boat shallow and risk sucking up sand. At $1200 a pop, I can't afford to replace the jet drive again.
I had an Evinrude/Johnson repair shop run a compression check last season because of this problem and compression was fine. To check out if the engine was fuel starved, I pressed the ignition key while running at full throttle and it chokes the engine down. I am thinking it is not a fuel problem but maybe a lack of fire to the plugs so I will probably have a shop run an electrical test on it.
Any advice?
Any advice?
