Hello
I just purchased a 1984 115 mercury, seemed to be running great till I mounted it on the boat and put it in the water
then the trouble started ..... lol
So anyhow when I put the boat in the water and had no hole shot at all ...... So after a lil reading I had it on the muffs and pulled off 1 plug wire at a time .... what I found out is that its not firing on cylinders 1 and 3 witch sure fooled me cause it sounds like it running great and not stumbling at all! .... So ..... where should I start looking first? Im fairly mechanically inclined but never worked much on electronics. Was think that it missing on those cylinders might help as where to look first? ........ any help would be greatly appreciated
Here's whats been done.
Comp test ..... all 6 between 125-130
Carbs cleaned
Fuel pump rebuilt
New impeller
TY in advance
TripleB
Carbs cleaned
Fuel pump rebuilt
New impeller
TY in advance
TripleB
