I have a 1979 115 mercury "tower of power" outboard. I lost spark due to deteriated wiring that caused the trigger to go bad. I replaced all the bad wiring and the trigger. I used a spark plug tester and have excellent spark on all 6 cylinders. Also did a compression check and all 6 cylinders check 118-120 psi. I try to start the engine and get a few sputters out of her but it just wont fire up. any suggestions on what the problem might be. Ive hooked up a gas tank full of fresh gas and its still the same thing happens.
