115 Johnson no spark
Funsize
While working on my 115 Johnson I bumped the hot cable going into the starter solenoid. Now I have no spark at the plugs and all of the lights,bilge pump, and live well aerators are not working. What did I burn up?? I checked all the fuses I could find and they are good.
emdsapmgr
You may have blown the main engine fuse, located in the main wire harness, close to the starter solenoid. That 20 amp fuse is for the engine only. If you've wired those other devices to the control box, it's possible that they may have overloaded that engine fuse. Repl the engine fuse and think about rewiring the other items direct to the battery on their own fuses.
