115 Johnson Faststrike starter 1996
Jamaga
I just got this boat and motor and it looks like an amateur experimented with it. I got really surprised when I hooked up the crank battery and it fried the post on the neg side of the battery. Without doing any thing else. Ignition switch off and the switch on the fuse panel was off. I really think the wiring is crossed up at the starter motor but have no way of knowing what to do to correct this. Can someone take a picture of their starter wiring or direct me to a wiring diagram that I can see?
jakedaawg
Red wire goes from battery to post on solenoid. Another goes from the other post on solenoid to starter. Blk wire goes from block to batterry.
jakedaawg
No Title
I just held a wire for illustration. Should be same set up on yours.
