Two unique things about your engine: 1. I has a single thermostat (vernatherm). 2. It has the bellcrank setup under the bottom carb to shift the lower unit. This setup is found on shifting crossflows up into the 1977 model year only. Both the 85 and 115 from 1977 year are the same as yours. The 77 140 won't adapt, as it's the new block version (dual thermostats) that came out on all V4 models starting in 1978 and going forward. When OMC designed the dual stat setup, they changed the bottom of the block, and it won't adapt to the older midsections.
