115 hp 1996 Gas leak after squeezing ball
1900clueless
115 hp 1996 Gas leak after squeezing ball. 1. Engine loads up at low speeds. 2. Loses prime at higher speeds 3. Gas pours out of Carb when not running after squeezing ball, there was a gas sheen behind boat at low speeds. Can't tell at higher speeds.. Which way to go, Rebuild carb or ball and gas line?
GA_Boater
Welcome.
Rebuild the carbs. A float is sticking or a needle valve and/or seat is worn.
1900clueless
Ok.. Id No. is not visible on tag, No. Id on freeze plugs. I want to buy the correct Carb. rebuild kit. (1996 115 hp.)
Honorary Supreme Mariner
2 carburetors with 2 barrels each or 4 seperate carburetors ?--------Posting pictures makes it all easy.
1900clueless
Ok rebuild all 4 carb.s still leaked from same carb. Success I was watching a You tube and there it was. older carbs have a plug the side bowl that wares out actually it is a bearing that falls out.. A little Marine Tech and all fixed. Thanks to one and all..
