115 ficht ram 2001 big rpm problem
nwox
Hi... I've this engine and I've a big problem...<br />The engine work correctly until 3500 RPM but cannot go over this speed..at this speed engine made a lot of noise and don't reach the max speed.<br />We have changed ECU, we have changed sparks, we have change injector.. and every time the engine seems to work well and engine reach 5500 RMP but after a week the problem reappear....<br />there is no error code in the ecu... and I don't know where is the problem..<br />please help me
Cricket Too
Re: 115 ficht ram 2001 big rpm problem
Welcome to iboats. Is this thing running hot, have you checked fuel pressure?
nwox
I've changed ecu, changed injector and spark plugs...sometimes i reach after a lot of try 4500 rpm... do you think is fuel pressure?how can I check it?
muskrat
is it a healthy engine what the compression.
nwox
the compression is ok... and the temperature also..
nwox
i've check indexing of spark plugs...<br />now i can reach misteriosally 5500 rpm but at 4000 rpm the engine have a lot of difficult to get higher rpm...it seems to stall for few seconds, after a lot i can reach the correct rpm.... anyone could help me?
bollard
If you have access to a diagnostic kit and laptop, that would be the best way to troubleshoot the problem.<br />By monitoring engine parameters, and then dropping individual cylinders, you should be able to home in on the problem. It has worked for me.
marinemech1
call brp customer service and ask where a dealer is close by<br />how did you afford to change all those parts?<br />a good tech should be able to diagnois problem ask brp
DHPMARINE
nwox<br /><br />Just an idea I haven't seen stated here.Maybe if posters gave more info when posting,someone might give a better answer.<br /><br />Just an example ...you've checked the indexing of the plugs. .... How?<br />Compression and temp are ok .... what are they ? <br /><br />I'm worried about the noise you mentioned.What is it ?<br /><br />I'm not picking you out for this post,but to all,give us all the info you can.<br /><br />I suspect your lift pump is bad.Probably the diaphram. <br /><br />DHP
nwox
is about 8 months that my dealer are trying to solve the problem... he don't know what is the broken part...<br />I've check indexing of spark plug by control that the spark is from 3 to 6 in a side, and 6 to 9 in other side...<br />I don't know the compression and the temperature value.. but my dealer say that it is ok....<br />8 months ago I take my boat to a dealer for this problem.. some "popcorn" noise at low rpm... (like 2700-3500 rpm)<br />I've changed ecu, upload new software, check injector parameters...and 4 months ago cylinder number 2 has been damaged... <br />the dealer changed it... but the problem remain... and now I'm trying to find an help on internet because I'm very very frustrating of this situation...<br />now the engine hesitate to go over 4000 rpm...<br />there isn't popcorn noise but it reach very fast 4000 rpm and after it makes a lot of difficult to reach 5500 rpm...<br />I hope with this story someone could help me...<br />thank you
nwox
i've changed crunkshaft sensor...<br />i've changed exhaust sensor<br />i've changed another injector<br />i've check throttle sensor<br />but the problem remain... tomorrow i'll change fuel lift pump... I hope this solve the problem..because I really haven't other ideas
