115 Evinrude Tachometer Still Dropping Off
COOLEY
Ive Got A1995 Evinrude 115 That Will Reach 1450 Rpm Then It Drops To Zero When Accelerate. I Have Replaced The Rectifier And Installed New Tach. Anybody Got Any Suggestions. Thanks
Joe Reeves
Re: 115 Evinrude Tachometer Still Dropping Off
Attach a volt meter to the "Purple" (12v supply) wire leading to the tachometer. With the key ON and the engine running, 12 volts should exist at that wire. If the voltage drops to zero at the same time the tachometer reading does...... then either a intermitent break exists in that purple 12v supply line OR in the black ground wire leading from the tachometer.
Note that a black/yellow wire connects to one of the "M" terminals of the ignition switch. Some boaters make the expensive mistake to take that wire for a ground..... DO NOT connect any other wires to that black/yellow wire terminal.
Your explanation of the problem usually identifies the water cooled regulator/rectifier as the problem area BUT replacing that item and also the tachometer pretty well cancels that scenario out UNLESS you somehow received a faulty regulator/rectifier assembly.
