hello all,this is my first post,i have gained invaluable info in the past from just searching the forums however i have a problem i cant fix.my engine is a merc 115 efi 2002 ,i believe it has the same powerhead as the yamaha f115.the problem is this-
low rough ilde in nuetral,rpm drops first on acceleration and sometimes stalls,on decelleration in nuetral the engine will also sometimes stall.fuel lines,lp fuel filter,plugs,fuel have been replaced,one section of the old fuel tube had perished and broken down inside.whilst running in nuetral @normal idle and @higher rpm 1200 i removed the injector plugs one at a time,1 &4 caused the engine rpm to drop but injectors 2&3 made no difference.i then pulled the spark plugs,same,all plugs appear to be producing spark.i then listend to the injectors,all sounded the same.i have checked the fuel pressure after the lp pump ,8 psi,and the fuel rail pressure,38 psi @idle,this seemed to fluctuate 2 or 3 psi in sync with the rough idle.
my thoughts are can i swap the injectors around to test ? or does this engine drop cylinders 2&3 for any reason? also should i try and claen the vst, pressure regulator and the idle control valve?
i see that Rodbolt knows his stuff regarding the yamaha hope he doesnt mind helping a merc owner! thankyou for any input
