northrivergeek
- Mar 11, 2006
- 38
I just bought a Shurflo Piranha 1100 GPH aerator, the out is barbed for a 1 /18 hose , instructions say to use smooth bore 1 1/8th hose not the ribbed, I cant find 1 /18 smooth non ribbed hose.. Ive found one place on the net that sells it so far and you have to buy the whole roll at 76 bucks I only need max 26 feet if I hook up both livewells to it .. I was wondering If I buy PVC clear in the 1 " if I can heat the hose up a little to soften it and make it fit over the 1 1/8th barb, will this still work ok its only 1/8 of an inch .. and then also would it be kosher to reduce that down at the spray head to 3/4 ?
No mention of it in the instructions! one way or the other..
Thanx in advance
Sean
Thanx in advance
Sean
