110 Johnson Primer Solenoid Question
busterb
Hi all, hope everyone had a "boaty" weekend. I pulled the carbs off of my new 110 Johnson this weekend, and in the process broke one of the 2 primer solenoid fuel hose nipples (the little hoses to the carbs). Question is, can I replace just the pump part, or do I have to replace the whole solenoid? The pump is connected to the solenoid with 4 screws. Thanks in advance!
Dhadley
Re: 110 Johnson Primer Solenoid Question
You can replace just the cap. No problem.<br /><br />Easy to break, aren't they?
busterb
Yes sir, they are! I pulled on that hose just a little bit too hard. I'm sure the plastic isn't exactly mallable any more though after 12 years! How much is just a cap Dhadley? I priced a whole new solenoid at the local Travis boating center and it was about $70. I also checked out Mastertech's website but couldn't find any primer related parts.
busterb
Dhadley
I believe it's #437228 and should be about 9.55.<br /><br />Good luck!
