110 Johnson bogging down
sdewease
I have an 89 Johnson 110 that is bogging down immediately under load. It runs fine on idle, yet when I put it in gear and throttle up it just bogs down. It doesn't die, it just absolutely refuses to pull the boat out of the water. I have changed the fuel lines and manifold and all of the filters and primer bubble. Any ideas would be greatly appreciated
Honorary Supreme Mariner
Post the results of a compression test.-------Check for spark on all leads.
fixit101
I had the same engine do that...would not come up on plane. I fixed it by removing the spring loaded check ball in the line/fitting coming out of the fuel tank. No problems since...that was five years ago...
sdewease
compression test results: cylinder 1: 88 psi, cyl 2, 3 and 4: 99 PSI. pulled up and ran fine once i fixed fuel manifold and then parked it. next time i tried to use it, it did it again
Testers are all different.----I would expect to see 120 on my tester.-----Perhaps remove the bypass cover on the low cylinder to look at the piston and rings.
emdsapmgr
You have a low cylinder. It is normal to expect that all compression readings will vary up to 10%. More than 10% variance and you need to have a look at the low cyl-maybe pull the head off for a look. That engine will seem to idle just fine on the trailer on 2 or 3 cyls. You need all 4 putting out max h.p. at wide open throttle. Check to be sure you have spark on all 4 plugwires.
