Recently purchased a new Rinker 280 EC and cant seem to make any of the 110 lugs work. All other shore power seems fine but the outlets aren't hot. Any ideas?
First, the obvious. Have you turned on the "outlet" breaker on the AC/DC switch panel? I know, just had to ask. Now, if you just have one outlet breaker, the first outlet in line will be the GFCI located in the head. Check to see if that has been tripped, if so, no other outlets will work. If you have 2 outlet breakers, than the other GFCI will be located in the galley area, check that one for a tripped condition as well.
Rinker,
Saw your post on the 12V coffeemaker as well. I'd ditch that in a heartbeat and get a regular home unit you can stash in a cabinet when not in use.
You said you bought a "new" 280. Did you buy it from a dealer? Have you addressed these issues with them? Have you contacted Rinker Customer Service? I'm an engineer with Proline, been in the business for 16 years now, Wellcraft, Hydra-sports, Intrepid, Stamas, and Proline. I know how this sh!t works...
