110 Evinrude Outboard cranking backwards? Need Help
tosha
Hello All,
I have been scouring the forum for some answers and am still not sure. We are looking to purchase a pontoon with a 110 Evinrude. The problem is that the motor will not start. I haven't seen the boat yet but the owner tells this story. "when I first got the boat we were having to hot wire it, a guy put an ignition switch on it and a kill switch for me. we took it out and got into some shallow water, sand and killed the motor. now it won't start on the switch and when you jump the solenoid it tries to crank backwards."
any takers on this crazy problem
all suggestions will help
Thanks in advance
flyingscott
Highly doubtful it's turning backwards it never would have started and ran right in the first place. He could be jumping the solenoid wrong which can cause more problems. I would also check the flywheel key if they hit something. If you are interested in the boat have it looked at by a reputable mechanic BEFORE purchase.
This is very suspect ,---It can not crank over backwards.
Chinewalker
That is correct. It is impossible for the bendix gear on the starter motor to spin up if the motor is running backwards. It sounds like you've got other issues going on.
tosha
it will not start, only crank and he says it looks like it it trying to crank backwards.... in my iboats research i have found that maybe the flywheel key sheared and it advanced time which would cause it to backfire and run backwards...?? I will go check it out on friday and see if he will let us take it to someone to check it out... may be as simple as the flywheel key... may be much more.
