Irecently purchased a used 1989 evinrude 110h.p.pro series outboard with a jet drive.Have had it out and running with no trouble until now.It appears there is a water leak at the thermostat housing but on closer inspection found it was coming from the exhaust adapter plate just above where the t-stat hsg. mounts at.Just curious if this is a common failure or a fluke,also wondering if the pro series designation means anything special.Any input would be much appreciated.
