lady athens
Thread starter- Joined
- Aug 31, 2008
- 5
I have read through the posts and can't find my answer.
'91 suzuki 100hp runs great in drive way with earmuffs on. I can rev up and down to idle no problem. When I put it in the river it will hardly idle and will try to go for a few seconds then I had the carbs adjusted, prop changed and a termostat changed last year and it ran fine. It has been sittin for the winter until now.
When I run it in the driveway there is good water flow coming out of the pilot hole but hardly any thing coming out of the water discharge holes in the rear of the engine. Don't know if thats normal. I have new gas and oil going to it.
Also even when it ran good the most rpms I could get out of it was about 3000. The specs say that the operating range at WOT is 5000 to 5600. It has always been low and still is after changing prop. This 100 hp is on a '90 25ft Ercoa that seems to be a heavy vessel.
Thanks in advance for your time!!
