100 hp Johnson 1972
dawgfan
Been sitting up for two years decided to get her going. I'm not getting any fire. I believe it is the amplifier or coil. Where can i find parts for this motor.Does any one have any easy checks for these parts?
Joe Reeves
Re: 100 hp Johnson 1972
Dawg.... If needed, I have one new improved universal OMC powerpack for your engine which I would discount. ReevesJ32@aol.com<br /><br />You can test your pack as follows.<br /><br />(Battery Capacitance Dischage Powerpack Test)<br />Various OMC Engines - 1968 to 1972)<br /><br />Purchase a small 12v bulb at your local automotive parts store (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. <br /><br />Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (purple wire). Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire). <br /><br />Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed. <br /><br />Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure.
dawgfan
Joe, <br />I tried the bulb and no glow. How much for the Power pack.I have been told I could put an automotive coil on this motor what are your thoughts. I have read the pros and cons.
