briangcc
- Jul 10, 2012
- 2,385
Did some googling so that might be dangerous.....
Prop - pretty much a given that dropping 1" pitch will increase your RPM by about 150-200RPM.
Motor - generally found your recommended rpm range to be in the 4400 neighborhood.
Basic math.....to get from your current 2000 rpm to around recommended 4400rpm would mean a change in 2400 rpm. Doing the math, you would need to DROP 12" worth of pitch to get your missing 2400 rpm. Assuming standard prop which seems to be 19" that would mean you'd need a 7 pitch prop. I'm sorry but I seriously doubt you're finding a 7 pitched prop to fit your outdrive to get you back into your max rpm range.
So....going off math alone, provided your outdrive isn't sounding like a blender, we just ruled OUT the outrdive (boat side) being the issue.
I'm no mental genius but given your motor can't swing the original prop, you have something going on with that engine. Heed these guys advice and start digging into it.
