10-blade Vs. 12-blade Impellers
Status
Not open for further replies.
jberenyi
I have two part numbers according to Jabsco. One has 12-blades #22120-0001 and the new part number is #18777-0001 but it has 10-blades. Which should I get? Is the 10-blade preferred for some reason?
rockyman
Re: 10-blade Vs. 12-blade Impellers
if it were me i would go with the new one if i could not get the original one ,either one will work i would think ,it seams a bit odd to me that there would be two different part numbers for the same piece of equipment.i would think the only difference would be that one will pump a little faster than the other thus causing a slight temp change , maybe ?
Status
