10 1/2 by 13 1/2 prop
ilovevintage81
Banned
I Have a 14 ft simiv aluminum boat with 40hp ski twinn im wondering about my prop what speep i can exspect im hearing my motor is big for boat is i get lower pitch like 10 what could i exspect or if i get like 15 i dont want to go super speed i may want a lower pitch any info would be great
ilovevintage81
Banned
Re: 10 1/2 by 13 1/2 prop
Another thing ive already filed it some cause of nicks so it may only b 10 now will that affect anything
steelespike
I believe your prop is the standard size.Of course the final size would depend on the application.
A stock 40 on a reasonably fast light boat should approach speeds around 30+ range.
What year is the motor and what sort of load/total weight of the running package?
What pitch you need would depend on your present wot rpm and gps speed.
You would not go to a lower pitch unless your rpm indicated it.
Usually decreasing pitch will slow the boat and increase power like a lower gear in a car.
Again the prop change would depend on your present performance.
ilovevintage81
Banned
Ok thanks maybe ill keep it the same cause im going to add like 150 pounds of wood to inside i just didnt want boat to be overpowered
steelespike
Thats a good starting point, get us the rpm and gps speed when you get her on the water.
What is the actual length,beam and transom width.
If she is a small 14 I wouldn't be adding too much weight.
ilovevintage81
Banned
16 inch transom 48 inch beam but gets to like 57in on top
