I've got a 1989, 3 cyl, oil injected, 40hp yamaha. It runs just perfect. I was going to change the plugs when I noticed number 3 (the bottom plug) was as clean as a whistle. The other 2 look like they had been used normally, perhaps a little on the oily side. <br /><br />I was thinking bad head gasket or some sort of water leak.<br /><br />I checked the compression cold, 1 was 95, 2 was 100, and 3 was 100. I ran the engine for a couple minutes and checked again, one was 90, 2 was 95, and 3 was 90. I don't know what is normal for this engine, but the good thing is that they are really close to each other.<br /><br />I don't know how I could test for a water leak. The compression seems fine and the motor runs like a swiss watch. Should I be concerned about the super clean number 3 spark plug?
