#1 and #3 fire weak! What causes it? Anybody know?
Jeremy90bay
Re: #1 and #3 fire weak! What causes it? Anybody know?
Happy boating then. I should have my mudule in the mail tomorrow, hope it fixes my no spark to 1 cyl issue. stay safe.
john from md
Good to hear you are back on the water again.
John
chitownborn
glad ya got it!!!!
maxum247
Took awhile but with the help I've gott'en from member's here on the iboats forum I "we got it".
Hey chitownborn! The motor's sounding good! :)
max!
puna
1989 125 hp Force Outboard. What would (most likely) cause the #1 and #3 cylinders to fire weak or not fire at all. I've seen this asked several times while searching the different forums, but I haven't been able to determine exactly what causes the problem or in my case solve it so far and my Clymer manual doesn't seem to cover the issue.
I know there's a reason for it, maybe more than one, anyone had this problem and discovered the answer or a way of solving the problem short of replacing everything from the ignition switch back to the motor a peice at the time until possibily finding the problem?
Could it possibly be partly mechanical in some way?
Thanks!
max!
:cool:whats up bra ! for me i had the same problem, i had to change the CD- MADULE on the right side cause i wasn't getting enought juice, check with the metering gauge and see if the CD-MADULE are working properly, hope that may help you!
