1/2" OD Smoker Craft motorwell drain
Top cover
I'm in the process of replacing the transom on my 16' Smoker Craft aluminum boat, but I can't find replacements for the two 1/2" OD motorwell drain tubes. I had to destroy the old ones getting them out. Does anyone know where I might be able to find replacements? The originals were aluminum, but I'll take what I can get.
jbcurt00
1/2 sounds small, absolutely sure they arent 3/4 or bigger?
Top cover
Yes, I measured the OD on both with calipers after I pulled them out and they were identical. I'm thinking they had to be factory by the looks of it. I don't dare go bigger though as the holes are already drilled just above the motor well. I'm wondering if Smoker Craft used a "bastard" size. The tag on the boat says it was built in 1974 so who knows what they did 45 years ago.
Top cover
Well for better or worse I rigged a solution since I needed to finish my project. It turns out that 1/4" brass pipe has an O.D. of 1/2"' the same as the drain tubes I removed. Since my new transom is 1-1/4"thick, I bought a 2" piece with threaded ends. I also bought a couple of 1/4" female threaded couplings which I cut in half and then ground to about 1/4" that I used as nuts. I pushed the pipe nipples through the transom, sealed the ends with 5200 sealant and tightened the homemade nuts. Since the inside ends aren't at the low point I may have to drill holes in the nuts to allow better drainage. It's not as pretty as the original, but I will paint it all when the sealant cures and no one will be likely to notice. Problem solved....I hope.
Top cover
Just a follow up on the repair I made per my above post. The drains function well and look much better than I had anticipated. After spray paint it looks like it belongs. It also drains about as good as before and I'm going to keep it as is. Success.
Top cover
No Title
Here it is Someone. Sorry it took so long. :)
