'06 suzuki 140 trim/tilt
rsv
my 06 suzuki 140 will trim down but not up, while using either switch, on motor or controls up forward. changed solinoid, but same result. Please help. thanks
steelespike
Re: '06 suzuki 140 trim/tilt
You'll get a lot better results in the Suzuki section this is props.
Does the solenoid click?
rsv
not that i can tell. i will take a closer look. thank you for the heads up
steelespike
Just speaking generically
If the solenoid doesn't react/click I would suspect the ground side or perhaps a broken or loose wire
that is common to both solenoid buttons.Check for voltage at the solenoid.
rsv
i found broken wire and reconnected it. i now get a clicking noise when trying to tilt motor up, but it still wont move up, just down.
Thank you. still trying to figure it out
rsv
i posted this in the suzuki section like you told me, but only getting answers in prop section so far. haha. thanks again
rsv
fixed it. sorry. i was calling the relay a solenoid. it was double trouble. i put old relay back on after i saw the broken wire, and was going to return the new relay to get my 100 bucks back. but after repairing wire the old one just clicked, so i ended up needing the new one. tilts up just fine now. Thanks steelespike for helping me
steelespike
Glad it worked out.Just electric common sense. I've never worked on a trim and tilt sometimes you get lucky
and when have someone who presses on they get it done.
