GIJeff
Thread starter- Joined
- Jun 5, 2012
- 41
Hi all,
I have a 2006 Tahoe Q4 Sport w/ a 4.3L Mercruiser engine (carbureted) and it will not start. It will turn over (most of the time) but if it starts it immediately stops. This just began happening yesterday.
It has worked fine up until this incident yesterday. After the last time it ran fine (few weeks ago), I did a bit to the engine and wonder what I did that could have messed things up. Here?s how I got to this point:
-I replaced my front seal, so I had the crankshaft pulley & harmonic balancer off. For better access, although completely unnecessary, I pulled off the pulley for the water pump, also.
-I attempted to repair a leak where crankshaft position sensor goes. I assume the O-ring is failing because it was leaking out of that hole, so we covered the sensor w/ Ultra-black Loctite and put it back in there. Oil still leaks so I?m going to purchase a new O-ring and try again. Any advice on this silly little leak would be nice, too!
-I completely cleaned and degreased the engine. I had the air filter off because I was cleaning it separately, so I covered the opening to the carb w/ a plastic bag and also covered the alternator. The rest of the engine, I sprayed down completely w/ degreaser, let it sit, then hosed it all off.
-I did not run the boat at all after cleaning it until I headed to the lake. When I first put in the water, I tried to start the engine. On the first turn of the key, the engine wouldn?t start. I tried to turn it again and it stopped turning over, as if the battery was dead. I assumed the battery was the problem. I tried to turn the key a few more times and all the boat did was ?click.? The engine didn?t turn over or anything. I had my fianc? pull me a few feet out of the water, I tightened all of my connections to the battery to make sure I had a good connection, and I turned the key again. Engine started. Back in the water.
-I have a common problem where when I first put in the water and get on the throttle hard, the boat falls flat. Separate issue (I assume) that I just haven?t dealt with yet. As long as I ease on the throttle to get it up to full speed the first time, the rest of the day is always smooth. This time, it seemed to be idling a little rough, and it was really touchy in regards to throttling up for the first time of the day. I had to take it very slow and slowly move the throttle forward. Got going, went WOT for about 5 min, then I came to a stop to put my wakeboard on, engine still running. After idling for another 5 minutes or so, the engine just stopped.
-I tried to restart the engine, and it wouldn?t start. Most of the time when I turned the key, the engine would turn over it just wouldn?t spark. Every now and then it would almost start, but then it sounded like it stalled. Pulleys stopped turning and the engine made a strange sound and stopped turning over. Sometimes when I turned the key it would just click. Sometimes when I turned the key it would sound like the battery was dead/near dead and wouldn?t do much of anything. I let it sit for a minute, tried starting it again, and a couple of times I got it to start for split second but then it would die.
-Towed to shore, pulled it out, and bought some Heet to put in the gas tank and some starter fluid to spray in the carb. Tried hooking it up to muffs and starting it on land using the starter fluid, wouldn?t work. Essentially did the same thing as it did in the water. It almost started a couple of times but then immediately died.
Any idea? I thought I may have gotten water (or degreaser) somewhere in the system while I was cleaning the engine, but why would it have ran for 10 minutes or so and then died?
