Wee Hooker
- Sep 11, 2005
- 618
Ok, admittedly I'm a 2 stroke guy ( and am pretty handy in fixing them) but when my 95' merc 15 hit the wall, I decided to take a chance on a newer 4 stroke. Found this one that was very clean, had low hours (used marginally as sailboat tender) and was maintained yearly at the local Tohatsu dealer. It also got a brand new carb at that dealer in 2019 as well. When I bought this engine just a month back, It started right up (cold) after 3-4 pulls in the sellers yard and ran fine . Restarted first pull several times after it warmed up too. Now I get it home and after it sat unused for a few weeks it's been a SOB . Took a dozen pulls to get it to cough. Now I can get it to start regularly but it will only run/idle for 10-20 seconds ( just long enough for the oil light to go out) then stalls regardless of what I do. Squeezeing the ball while it runs has no effect. Moving the throttle position up while it runs ( even to the restart mark) seems to make it die immediately. Tapping the carb (to free a possibly sticky float) has no effect either. Tank, primer and line are brand new ( as is the gas). I've also verified that the fresh gas is getting to the carb . I've also verified good spark at plugs. As an aside, once it stalls, it often needs to sit a few min before it will start again. I suspect it is either that mysterious auto choke system / the carb is running too rich. Any thoughts/experience on these older carbonated engines is greatly appreciated as I'm running out of ideas!
