'05 Starcraft Aurora breaker/fuse popped
05Aurora
Guys, I have a 05 Aurora 2015 and the breaker /fuse under the "water pump" toggle pops out when I try to turn it on. Is that a fuse or a breaker as if I have a short somewhere ? Also, what is the best fix ?
Thanks for any help!
Pugetsound
Re: '05 Starcraft Aurora breaker/fuse popped
Check the wireing from the water pump back to the switch and from the switch to the power source. Its either a feed wire to the pump going to ground or the pump wont turn. use a VTM meter and check if both wires on the pump go to ground, one should the other( hot) lead should not.
05Aurora
Pugetsound, Thanks for your advice. I will try that tomorrow since I will have time to trace it out. I will let you know of the outcome.
