04 Q4 SF Dash Switches Inoperable
Shark59!
None of the switches on my dash are working other than the blower. Master switch is on, motor cranks fine. Any ideas???
AgentJ
Re: 04 Q4 SF Dash Switches Inoperable
Check the fuses.
Im Lon 2
Did you check the fuse that is right off the battery?
If you just hooked the battery up this season for the first time make sure you hooked up all the wires, and didn't miss any of them.
Shark59!
I checked the battery and every fuse...all good. Traced all wires and they're connected. Finally started checking each individual connector and found the one attached to the main power switch had corroded and was no longer providing contact. 1 new connector and everything's working again! Thanks for the suggestions.:whoo:
BoatDrinksQ5
hmmm - makes me think getting under there and going a little crazy with some spray silicone and/or Boeshield(sp?) (rust protection...like spray wax almost...)
i do similar in the engine bay... i suppose up front is bad also for corosion.
