I have a friend that inherited a 2004 Sea Ray 280 that has been stored outside on a trailer its whole life. In the last year the boat was stored off center with the starboard side lower than the port, with the bottom drain plug left in and the bilge held water for some time.
The transom moisture levels check ok but the engine stringer forward are high as well as the stringer around the fuel tank.
We have drilled and checked all areas in a grid and found some darker looking wood on the lower stringer but rotten wood on the starboard stringer around the fuel tank.
The boat has been completely disassembled including the fuel tank. The stringer glass around the tank was removed and proved the wood was bad on the corner with the remaining wood dark around the staples?.Sea Rays way of laminating I guess?. and wet so it has been removed.
The plan??
Remove and replace the fuel area stringer with ply and vinylester
Remove the engine stringer cap and replace the wood with NidaBond?We know that Sea Ray uses some sort of plastic composite in the engine stringer but we are not sure how much and where at this point and really wanted to keep the original glass.
Remove the small connecting section between the engine stringer and fuel area stringer and fill with NidaBond or wood and vinylester
Re apply gel coat?..since we already have it
The question??
Will vinylester bond to the original cured vinylester glass that Sea Ray Used?..........worried that I may need to use epoxy?
Should we take a different approach?
Thanks Guys!!
The plan??
The question??
Thanks Guys!!
