03 50 hp 2 stroke 3 cyl won't fire
gcrosby111
recently took possession of a 2003 merc 50 hp...I replaced the fuel tank, all fuel lines, spark plugs, water pump..I pulled the carbs and thoroughly cleaned them, rebuilt the fuel pump. I had it running yesterday(Finally)...I planned on a lake test today,...went out this morning and the boat turns over but will not fire...I'm using water ears as well as having the foot submerged in a tank...Haven't done a compression test...I can't understand why it won't run today when it ran great yesterday...I pull the plugs and they are wet with fuel...Flooding?...I'm at my wits end...don't have the money for a mech to look at it.....any ideas?
Silvertip
Honorary Supreme Mariner
Re: 03 50 hp 2 stroke 3 cyl won't fire
Did you inadvertently hit the kill switch???? Did you check for spark???? What is your starting procedure? Did you set float level and drop according to spec when you worked on the carbs???? Lastly, what makes you think having both muffs and the engine in a test tank would be of benefit. By having muffs on the engine you prevent the pump from drawing water. One or the other but not both. It ran yesterday because it had spark and fuel then. It doesn't run today because it has no spark for the reason I mentioned earlier or you used an incorrect starting procedure, or the carbs were not assembled correctly. At this point compression is the last thing you need to check
gcrosby111
It ran great after the carbs were removed and cleaned yesterday, It would idle perfectly I let it idle for about 20 minutes. I disconnected the fuel and let it run till it was out of gas. and yes it was peeing and the overheat alarm wasn't going off.. This morning I reattached the fuel line, pumped the bulb a few times and it would not fire. I pulled the plugs and turned the engine over a couple times, then re-inserted the plugs. After doing this it would try to fire, sputter a couple times then nothing...I checked and the fuel pump is pumping, I checked for spark at the plugs and i've got that. I'm at a loss for what it could be....I'm considering, as a last resort, starter fluid.
sxmerc
DON'T USE STARTER FLUID ON YOUR OUTBOARD!!!! You can severly damage your engine. Sounds as though you flooded the hell out of it, or as Silvertip stated, no spark at one or all. My guess is something in the carbs, or fuel pump got assembled incorrectly.
gcrosby111
After I rebuilt the fuel pump and tore the carbs down it ran great..Now today it won't fire,..I'm getting spark at the plugs(pulled plug and touched metal, saw nice spark on all plugs).. After I try to start it, i pull the plugs and they are wet with gas...And starter fluid is me getting frustrated...
Silvertip
You failed to tell us your starting procedure. You also said you squeezed the bulb a few times. You squeeze it until it firms up. If it doesn't the float in one or more carbs is not adjusted properly or the needle and seat are not sealing and you are pumping fuel into the engine before you even attempt to start it. Are you using the fast idle lever? Are you pushing the key in to activate the enrichener while cranking. See why I asked what your starting procedure is. It may have started yesterday because you got lucky with a bad starting procedure. It didn't start today because you did something wrong in the carbs or you are using the wrong starting procedure.
gcrosby111
Pumped the ball till firm(7 to 8 times), fast idle lever up, turn key to start position, push in for enrichment, start....gives an initial sputter then just turns over..I pulled the carbs again to double check the floats...they are functioning, also ran a small wire through the jets, all clean...The plugs are still soaked when I pull them...Guess i'll buy rebuild kits for the carbs and see if that helps
Silvertip
How did you test the float operation and did you adjust the level and drop? If it's flooding on you, why are you using the enrichener?
gcrosby111
I tested the float by blowing into the intake line(with carb off and bowl off) then moved the float up until the air flow stopped. I bent the tab that holds pin slightly and retested it by blowing..same results...If there is a better way of doing this please let me know..I'm new to marine engines
gcrosby111
Finally got it running....the fast idle lever was not going all the way to full position. Took her to the lake and she ran like a raped ape.....she still tough to get started but once she runs she sounds great and runs out nice.. I'll work on the starting issue at another time..thanks for the help
Silvertip
You set the floats wrong because you tested them wrong. Invert the carb. Float should be parallel with the gasket surface or whatever your service manual says. With carb inverted, blow into the fitting. air should not pass. What you did was to "force" the float up. That has nothing to do with float level and is apparently why the engine floods so easily. It also allows the fuel level to be way to high in the carb. You bend the tab on the float arm to set the height.
As for the fast idle lever, although it travels to nearly vertical, it DOES NOT open the throttle fully. It is not supposed to. What did you do to that?
gcrosby111
I had a neighbor come over and start the motor while I worked the throttle levers....She fired and ran right away...after she idled for about 30 mins we decided to take to the lake and see how it would run....At the lake i initially had to manually work the throttle at the carbs to get it fired....We made a couple runs at half throttle then went to full throttle for a bit..once back at the ramp..I shut it down for a few mins and tried it again..the previous owner(my uncle) came down and said that the fast idle wasn't going as far up as he remembered...he worked the lever and this time the engine actually reved higher then it had previously done at the house....I think that maybe the fast idle had some crud in it and needed to be worked out....My uncle was amazed at how good the boat ran....I don't have a manual but that will be the next investment. I'm used to old harley's and I'm new to marine engines...this is definitely a learning experience for me and i value all the things I'm learning by reading and participating in the forums...Since it's running, I'm not touching the carbs again until i can get that manual..Thanks for the help
