00 Johnson 90 lower unit HELP!
Reyc
Fairly new to boating and I managed to get the lower end off to have the skag repaired but cannot for the life of me get it back on. I can’t get my control rod reconnected. Anyone got any ideas or tips for me?
jakedaawg
Sometimes it's easier to remove the lower cowling so you can guide the shift rod into position and have a helper work the linkage.
Chris1956
Honorary Supreme Mariner
The dogleg should face forward. When you shove the gearcase into place, the motor will likely shift into reverse. Turn the prop to mate the driveshaft splines with the crankshaft. After the gearcase is nearly in place, use a punch to pull up the shift rod, into forward, so it can be reconnected to the shift linkage.
