00 90 hp johnson tach will not work properly
davcr59
Hi
I have a 2000 90 hp johnson looper and the tach is reading 1000rpm at idle and when I rev the engine up the tach goes to 0 rpm. The reason why I installed the tach is because the engine rev limiter is kicking in and I do not believe it is turning 5500 rpm. I have a 6 pole tach and I just wondering if I should change the powerpack.
Thanks
bktheking
Re: 00 90 hp johnson tach will not work properly
I wouldn't replace anything until you get the tach sorted out, it may have nothing to do with the powerpack.
Barnacle_Bill
Look on back of the tach and make sure it is set to 6P (pulses) or 12 poles. If that is set correctly test your recifier/regulator.
