My Force 50HP Stator coil should read around 750 ohms resistance which it does, and no continuity to engine ground. However when cranking, I'm only getting around 0.25 Volts AC from the two blue wires. I have the Pre-D model (1987). I believe I should be getting around 200VAC with a multimeter so that tells me a problem related to the stator or magnets.
Could the magnets come off or uncharged? From what I can tell, I have a thin ring of ceramic magnets around the inside perimeter of the flywheel. A screwdriver will not hold here but will faintly stick. OK or not, I'm not sure. So most likely a bad stator? I also tried unplugging at the rectifier.
