​1997 225 Johnson Ocean Runner high idle
festerized
1997 225 Johnson Ocean Runner SJ225TXEUD
Motor is idling around 950-1,100 RPM, around 800-900 in gear. I recently installed a new CDI power pack, CDI optical sensor and CDI stator.
I also have an issue with my cold start after installing new electronics which caused my motor to idle around 1,300 for about 5 minutes then it would idle down. Which isn?t that bad, except if I shut down the motor no matter how long it was running it would take another 5 minutes to lower again.
I grounded out the white/black wire from port sensor until my new sensor comes in. Once I grounded out wire the RPM?s came down to 950-1,100. Idle should be around 800?
Any ideas?
