Hi there,
My outdrive is being serviced! The impeller is being changed, since it is broken.The boat was built in 1979 and I have no idea, what has beend replaced the last few years. It is runnig smoothly, but the thing are getting older...
What would you suggest doing, once the outdrive is off and take the opportunity of it. What would you expect this to cost (the parts?)
The mechanic I have said to me if I was changing the rubber tubes I also need to replace the steering issue and the one for the gears. I didn't understand why. Maybe you have an answer.
Thanks a lot!
best regards,
popey
Thanks a lot!
best regards,
popey
